Problems calculating flow through porous domain |
March 8, 2017, 06:14 |
Tim
Rep Power: 12 |
Hi all,
I have some problems calculating a simple flow through a porous domain. I've ran my simulation both with Fluent and CFX. While Fluent solved my problem without any circumstances, CFX showed me a floating point exception at the first timestep (with a default setup). When I activate the Local Timescale Factor and set it to 0.01, CFX runs too. however, the speed of convergence is massively slower... I found out that the higher I set the resistance in porous domain the smaller I have to set the timescale factor. Is it because of the high pressure gradient? A finer mesh didn't change anything... Does anyone have experiences in this or a clue? Thanks, Tim |
cfx, fluent, porous domain |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
Rotational porous domain | Pifpoffele | CFX | 1 | July 6, 2015 12:46 |
Porous domain problem | Roland R | CFX | 2 | July 6, 2015 05:51 |
Flow through a porous domain - domain issues | r61514 | OpenFOAM Running, Solving & CFD | 0 | February 6, 2015 13:04 |
Porous domain in a flow field | rikio | CFX | 7 | August 25, 2009 23:39 |
