February 13, 2001, 16:48 |
Viewing residuals
I can not view the residuals in CFX-Visualise. I am using the expert control parameter OUTPUT EQ RESIDUALS set to T as described on page FAQ-35 of the manual. I am using CFX 5.4.
Does anyone have a suggestion? |
February 14, 2001, 03:40 |
Re: Viewing residuals
We use gnuplot and fieldview to see the residuals. Visualize is a bit to simple for viewing all the results.
February 19, 2001, 09:47 |
Hi Bob,
when you load the res file into Visualise, make sure you have the 'Variable Interest Level' set to All, and then select the residual fields you would like to look at. They will then be loaded into Visualize. Hope this helps, Phil |
[Tutorials] Tutorial of how to plot residuals ! | wolle1982 | OpenFOAM Community Contributions | 172 | December 6, 2024 07:20 |
what to monitor besides residuals? | franzdrs | FLUENT | 5 | March 21, 2013 04:59 |
Mesh size and solver residuals... | Scott | CFX | 5 | December 15, 2008 18:10 |
Convergence - scaled vs unscaled residuals | HS | FLUENT | 1 | November 7, 2005 06:45 |
residuals | Karl | CFX | 2 | June 25, 2003 00:13 |
