March 6, 2017, 21:18 |
Torque calculation of film cooled blades
I am trying to calculate the axial torque of a film cooled blade.
The exit of the film cooling holes on the blade has a interface surface, so the entire blade surface, as I model the airfoil, cooled be selected. However, the calculated value of the torque on the blade using the function "torque_z()@Blade" was lower then expected. So I tried to find out how CFX calculates torque. In case of the wall region, the torque can be calculated by the pressure and shear forces. (areaInt_y(Pressure * X)@Blade - areaInt_x(Pressure * Y)@Blade) + (areaInt(Wall Shear Y * X)@Blade - areaInt(Wall Shear X * Y)@Blade) In case of the film cooling hole exit, which is an imaginary wall in the fluid passage, could be a sum of pressure force and mass flow*velocity. But, this also shows difference in the values. (areaInt_y(Pressure * X)@BLADE - areaInt_x(Pressure * Y)@BLADE) + (-massFlowInt(Velocity in Stn Frame v * X)@BLADE + massFlowInt(Velocity in Stn Frame u * Y)@BLADE) So, I want to know how to calculate the film cooled blades torque right, and how the torque is calculated at planes in a fluid region. |
film cooling, torque, turbine |
Problem in Torque calculation | Achilleas | ANSYS | 0 | October 1, 2015 08:56 |
Torque calculation of 2D VAWT Wind Turbine | Anonymized_JL1 | FLUENT | 14 | September 26, 2013 03:35 |
Strange torque calculation | danny123 | OpenFOAM Running, Solving & CFD | 5 | May 7, 2013 04:59 |
Torque calculation in pumping equipment | Kirill | Main CFD Forum | 0 | June 26, 2007 16:59 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
