Turbulence model
Old   February 6, 2001, 10:55
Default Turbulence model
Jose Caridad
I am trying to simulate two-phase flow (air-water) through a centrifugal impeller but when i look at the residual plot in the canvas window the epsilon variable is in the order of 1E5 or higher. It is that correct? It is possible to estimate a "good value" for this variable? I really appreciate all the help you can give me.
Regards,
Jose Caridad
Old   February 7, 2001, 05:46
Default Re: Turbulence model
Jan Rusås
Very difficult question,
The residuals are not non-dimensionalised, so if you want a lower value you can reduce your massflow ! You can also read in the manual in the section about convergence problems, some of the hints there might help you reducing the residuals, especially activating deferred correction. Be careful with how you set the inlet conditions for k-epsilon, check if there is a high jump in the values at the inlet and into your flow domain.
Regards Jan
Old   February 9, 2001, 14:33
Jose Caridad
Thanks Jan,
I have tried all the hints recommended in the manual (relaxation factors, more accurate solution of the inner iterations, deferred corrections...).
All the variables show excelent convergence but the residuals for epsilon remain high (about 1E3 and 1E5). I have not tried to give explicit values of k and epsilon at the inlet. Instead, i especified values for turbulent intensity and dissipation lengh scale. Is it the mistake?
Regards,
Jose Caridad
Old   February 9, 2001, 20:58
Jan Rusås
Hi Jose No probably not, It is a wild guess. I just remembered years ago someone told me that a value of k and epsilon which was decades higher than just downstream the inlet could lead to numerical troubles. Your values for epsilon is not uncommon. A quick, and mayby dirty, way to exaimine your values are by scaling them, i.e. eps_residual/eps_ave_inlet compare with the other scaled values.
Regards Jan
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 10:02
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 14:57
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 11:26
Fan heater model: what turbulence source to use? andy20 CFX 7 March 3, 2008 17:42
SSG Reynolds Turbulence Model Georges CFX 1 February 28, 2007 17:15
