March 5, 2017, 07:19 |
CFX not running in MPI distributed mode
Rep Power: 11 |
Hi all,
I'm testing a CFX run on my university's HPC cluster using 2 nodes each with 16 CPU cores, hence a total of 32 processes. Having read relevant previous posts on setting up distributed parallel runs on this forum, I was able to start the simulation on both nodes, but soon it fails with information below from the .out file. +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The ANSYS CFX solver could not be started, or exited with return | | code 255. No results file has been created. | +--------------------------------------------------------------------+ 1. For the same simulation, I was able to run it in "MPI local parallel" mode on one of the nodes. So I don't think there's anything wrong with the CFD setup. Although I do experience unusual slowness in this local parallel run on a remote HPC node, compared to running it on my local machine. 2. My command is as below and if anyone can point out what I've done wrong, it'd be much appreciated. cfx5solve -batch -def [filename].def -start-method "MPI Platform Distributed Parallel" -par-dist "[node list]" Thank you. |
March 8, 2017, 16:40 |
Erik
Rep Power: 23 |
Distributed requires setup of the distributed cluster.
Local parallel works out of the box. It sounds like distributed wasn't set up properly on your university nodes. Some of the setup is: - Remote Desktop Acess - hosts files and machine types populated - MPI installed on all machines - firewall exceptions - Caching passwords if applicable See the Installation documentation for more info. |
CFX parallel hp MPI problem | fluidmechanics | CFX | 5 | June 19, 2013 19:05 |
Sgimpi | pere | OpenFOAM | 27 | September 24, 2011 07:57 |
HP MPI warning...Distributed parallel processing | Peter | CFX | 10 | May 14, 2011 06:17 |
Statically Compiling OpenFOAM Issues | herzfeldd | OpenFOAM Installation | 21 | January 6, 2009 09:38 |
Is Testsuite on the way or not | lakeat | OpenFOAM Installation | 6 | April 28, 2008 11:12 |
