March 1, 2017, 02:52 |
a problem for cfx-pre
Jiacheng Wang
Rep Power: 9 |
Hello everyone,
I am trying to model a simple membrane module with CFX. Currently, I have finished a msh file and I prepare to import the msh into CFX-Pre. However, I can not find any methods to choose a face to define the boundary condition. I can only choose the whole wall faces, but not a single face. I'd like to know that how to solve the problem. I'm a new one in CFX. Hope for help and I would appreciate that very much. jackeyson |
March 1, 2017, 03:02 |
urosgrivc
Rep Power: 12 |
In the mesher make NAMED SELECTIONS
with this you will be able to select faces and give them names, you willl be able to call those names of faces in cfxPRE. I suggest you always use named selections these are wery important and usefull. |
March 1, 2017, 03:14 |
Jiacheng Wang
Rep Power: 9 |
Thanks for your help and suggestion!!
March 4, 2017, 14:09 |
inlet velocity
Rep Power: 11 |
how i can use a formula for inlet velocity or other conditions?
I want to set inlet velocity of a rotating domain to V=Va+V0.sin(Wn.t) my model is a propeller. |
March 5, 2017, 04:57 |
Rep Power: 144 |
Use of CEL, the CFX expression language, is covered in the CFX tutorials. You can download these from the ANSYS customer website.
March 5, 2017, 12:58 |
#6 | |
Rep Power: 11 |
I know how can i create an expression. but I don't know that how i can set default domain->boundary details- > Mass and Momentum values. In Normal speed, cart. Vel. components , ... we can type numbers only. |
March 6, 2017, 00:18 |
Rep Power: 10 |
sohrabmajd,
before you enter de expression, you need to click the "alpha squared root" button, which is located beside the units drop-down menu. |
March 6, 2017, 01:31 |
Rep Power: 144 |
...... this is covered in the tutorials as well
[Other] engineFoam new mesh problem | ayhan515 | OpenFOAM Meshing & Mesh Conversion | 5 | August 10, 2015 09:45 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 05:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 06:59 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 20:13 |
CFX new user, problem with solver and PRE settings | Vijesh Joshi | CFX | 1 | March 13, 2006 23:42 |
