Problem with parameters
Old   February 21, 2017, 16:28
Default Problem with parameters
Maria Clara Cardoso
mariaCFD is on a distinguished road
Hey, I've been studing the mesh of a geometry and after some design point that I've created it starts failing.
the following message appears:
Update failed for the Design of Experiments component in Response Surface. 5 Design Points failed to update and have been preserved in the project. From the Project Schematic, edit the Parameter Set cell to attempt a single Design Point update and review the detailed error messages.
and at each design point this message appears
Update of the Solution component in CFX for Design Point 13 failed: The solver failed with a non-zero exit code of : 2
thanks
mariaCFD is offline   Reply With Quote
Old   February 21, 2017, 17:31
You will have to open the output file of those runs to see what really happened. The output file gives more useful error messages (most of the time).
Old   February 21, 2017, 17:46
Maria Clara Cardoso
how do I get to it?
inside of CFX folder, and then..?
Old   February 21, 2017, 23:55
There probably is a way to get at it inside workbench but I find that a bit painful. So I get it out of the workbench project directory. Just have a look in the project directory and you should find it soon enough.
design points, optimization, parameter set
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 11 September 4, 2024 05:28
Fluent Parallelization Problem After AC Power Dropped pawl Hardware 5 November 13, 2016 07:08
How to modify Arrhenius rate parameters in Fluent ?? Kashif123 FLUENT 0 October 25, 2016 22:59
[DesignModeler] Problem with parameters in DM germinal ANSYS Meshing & Geometry 3 September 4, 2016 23:33
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
