CFX5 Momentum sources
Old   October 2, 2000, 13:23
Default CFX5 Momentum sources
Dr David Hargreaves
Hi
I have a duct internal to a flow domain through which I require a fixed volumetric flow rate, regardless of the surrounding flow regime. Is there a simple way of doing this with momentum sources in CFX5.3?
Thanks
Dave
Old   October 4, 2000, 00:30
Default Re: CFX5 Momentum sources
joecfd
You'll basically have to ball park the source term, see what flow rate you get, then if it is not right adjust the source term accordingly. Keep doing this until you get the flow rate you want.
Simulation of Axial Fan Flow using A Momentum Source Subdomain Liam CFX 28 July 16, 2013 09:24
Please help with momentum sources and actuatordisk Nikolas FLUENT 1 June 16, 2010 07:54
Derivation of Momentum Equation in Integral Form Demonwolf Main CFD Forum 2 October 29, 2009 20:53
sliding mesh and momentum sources term run error luan Siemens 4 June 29, 2008 19:38
Electrostatic field and momentum source with CFX5 Domenico CFX 0 May 5, 2005 12:45
