2D Axisymmetric modeling
Old   September 20, 2000, 18:04
Default 2D Axisymmetric modeling
Bobby Malone
I am having problems generating a 2D grid in CFX 5.4. When I generate a thin solid of less than about 30 degrees in the radial direction, I get various fatal errors dealing with the quality of the grid. What is the procedure for generating a grid with only a single node in the radial direction?
Old   September 22, 2000, 02:02
Default Re: 2D Axisymmetric modeling
joecfd
You cannot explicitly generate a 2D grid in CFX-5.4 It only does 3D.
So, that basically leaves you with trying to gererate a thin layer of tetrahedrons, say a few elements thick, and then apply symmetry boundary conditions on either side.
You need to make the geometry narrow enough to be "almost" 2D. Be careful when doing this though as it is easy to generate bad tetrahedral elements which the solver may not be able to handle.
Old   September 24, 2000, 03:44
Li Xinfeng
In fact, cfx-build can get the 2-d axisymmetric modeling,but it's a 3-d solid indeed and k=1
Old   December 4, 2000, 06:27
M.S valipour
dear sir i want know more than more about CFX code. please send me many of results from problem invstigation with code & please told me about flexability this code.
Old   December 4, 2000, 06:35
M.S valipour
can I use cyclic boundary condition to modeling axisymmetric flow ? mechy OpenFOAM 0 July 8, 2011 15:16
Modeling the flow in a fully axisymmetric case %e2%80%93 results with no peripheral symmetry evgenia OpenFOAM Running, Solving & CFD 0 February 14, 2008 11:23
May Focus Area: Turbulence Modeling Jonas Larsson CFD-Wiki 0 May 2, 2006 12:48
Modeling Flow/Saturation/Absorption in Fibers Gene Dougherty Main CFD Forum 0 June 6, 2003 15:49
CFD Modeling of Two-phase Flow in Small Dia.Tubes Eric Poindexter Main CFD Forum 2 September 22, 2000 10:21
