February 17, 2017, 10:22 |
Best Way to Set Up a Diffusion Problem
dfranken
Rep Power: 10 |
I am trying to run a simulation where I have ideal air diffusing into ideal helium. I have set up a variable composition mixture and initialized one area of the simulation to have only air and the other to have only helium. When I run the simulation I am not getting accurate results using a well proven kinematic diffusion function. Does anyone have any insight on a better approach to this problem? Thanks.
February 19, 2017, 17:48 |
Rep Power: 144 |
Have you done the standard checks for simulation accuracy? https://www.cfd-online.com/Wiki/Ansy..._inaccurate.3F
February 27, 2017, 15:39 |
Erik
Rep Power: 23 |
You define the molecular diffusivity. The program will also add in turbulent diffusivity from fluid motion if you are using a turbulence model. Is your flow laminar? Are you using a laminar model or turbulent? If turbulent, additional diffusion is added which possibly shouldn't be there?
Otherwise, Check the FAQs as Glenn suggests. there could be numerical diffusion, convergence not good enough, etc. I've done many diffusion models and I know it works properly and matches the complementary error function equation for diffusion, where you set 50% at the initial interface location. |
March 1, 2017, 14:03 |
dfranken
Rep Power: 10 |
Thanks, I have looked at the FAQs but haven't found anything that really helps. My flow is laminar as well. I will try looking to see if there is some turbulence variable which may be influencing the results. If I fix it, I'll let you know.
air, diffusion, gas, helium |
[ICEM] ICEM Scripting Issues | tylerplowright | ANSYS Meshing & Geometry | 33 | September 27, 2021 16:35 |
How to set BC for the mass diffusion? | Pete | FLUENT | 7 | September 2, 2017 05:28 |
solving a heat diffusion problem, using Crank-Nicolson AND gauss-Seidel method | vagelis Karvounis | Main CFD Forum | 3 | March 25, 2015 08:44 |
Thermal phase change set up problem | Danial Q | Main CFD Forum | 1 | July 10, 2014 14:41 |
Solve a mass diffusion problem | Roberta | FLUENT | 0 | November 26, 2008 01:47 |
