Problem with Parametric Study
Old   February 17, 2017, 09:09
Default Problem with Parametric Study
Picopico is on a distinguished road
Hi everyone,
I would like to characterize the behavior of a variable using a parametric study.
Specifically my simulation has as objective the evaluation of time required for filling a deformable fiber preform having a certain porosity. The study is done in transient and the characterization must be done by changing the stiffness of the fiber.
Using the solution update the numerical scheme converges, but when I try to start the parametric study with the same parameter that first guaranteed a good solution (and that is the only input parameter), the result is completely different. Also the mesh is the same
Good solution with stiffness of 50 [MPa]
Starting the parametric with with the same settings as the previous case:
I'm using Ansys Student CFX 17.2
Does anyone know what is due to the error?
Thanks
Picopico is offline   Reply With Quote
Old   March 7, 2017, 18:56
Fabio Teixeira
Fabio_Teixeira is on a distinguished road
Check the Solver run configurations . On Initial Values tab, for a transient analysis, you should pick "Initial Conditions".
If you let the default option "Current Solution Data (if possible)", when you run a second solution, it will take the final step data from the first solution and use it as initial condition.
Fabio_Teixeira is offline   Reply With Quote
Keeping the results of a parametric study aminem FLUENT 0 June 1, 2016 06:43
Workbench in batch mode with parametric study (design point) Veronique Pe ANSYS 0 June 1, 2016 04:56
Grid independent study problem wzhang11 STAR-CCM+ 5 February 19, 2016 10:03
Grid independence study problem Bisht STAR-CCM+ 8 February 2, 2016 14:28
Convergence Rate Study Khurram Main CFD Forum 1 May 15, 2002 06:05
