Air inlet boundary condition for free surface in open channels
Old   February 15, 2017, 06:21
Default Air inlet boundary condition for free surface in open channels
mohammad.ramezani
mohammad.ramezani is on a distinguished road
hi
I want to know that for the Air inlet boundary condition, above the water surface, which of the followings must be determine?
1. A velocity similar to the water velocity?
2. The real air velocity above the water surface?
3. A portion of the water velocity at water inlet?(for example 1/100)
4. A linear velocity profile that at water surface has a velocity equal with water and reaches to zero at higher levels?
5. Or there is no need to define an air inlet, and choosing homogeneous model is sufficient for simulation?
Thanks a lot
mohammad.ramezani is offline   Reply With Quote
Old   February 15, 2017, 17:58
Please post an image of what you are trying to do showing the flows you want to model and the boundary conditions you intend to use.
Old   February 17, 2017, 09:11
mohammad.ramezani
this is a siphon spillway,in which, in the upstream the reservoir level rises by increasing the discharge.
at the upstream:
1)water inlet height= 0<h<0.35m
2)a wall=0.35<h<0.39
3)air inlet height=0.39<h<0.45m
(water height of the reservoir would not increase than 0.39m)
the down stream is 0.25m drown and the outlet is opening
Thanks a lot for your reply
Old   February 19, 2017, 18:54
Your questions are in the reverse order to what you should consider them.
First: Homogenoeus or inhomogeneous is chosen depending on whether the free surface is distinct and clear or whether bubbles, foam or other features you do not intend to directly model are present.
Once you have made that choice you need to look at the boundary conditions.
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Condition of Air velocity in Open Channel simulation wes1204 OpenFOAM Running, Solving & CFD 0 May 9, 2014 06:08
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 11:59
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
