Drop in pressure in Reaction Turbine
Old   February 13, 2017, 16:51
Default Drop in pressure in Reaction Turbine
MissCFD is on a distinguished road
Can somebody explain me why when the water flows through the Francis turbine its pressure reduces ? What happens with the speed differential \frac{V^{2}_{2}-V^{2}_{1}}{\rho g} if we consider 1 as the inlet of the runner and 2 as the outlet of the runner. V_{1} is higher than V_{2} ...
Thank you for your help.
MissCFD is offline   Reply With Quote
Old   February 14, 2017, 15:29
turbo is on a distinguished road
Pressure drops because it is a turbine. Turbomachinery working principle.
turbo is offline   Reply With Quote
problem in the calculation of pressure drop for an axial turbine aja1345 FLUENT 0 January 1, 2016 15:07
Pressure Drop mumtaz ersan Main CFD Forum 3 April 23, 2015 10:20
Segmentation fault in running alternateSteadyReactingFoam,why? NewKid OpenFOAM 18 January 20, 2011 17:55
Pressure drop? Munni FLUENT 4 March 25, 2010 15:21
Pressure drop in a heat exchanger Diana FLUENT 5 December 13, 2007 10:33
