No Static Entropy Generation
Old   February 11, 2017, 13:23
Default No Static Entropy Generation
Giacomo Mingardo
gmingardo is on a distinguished road
Hi everybody,
I'm doing a simulation at very low RE number (1e4) and very low velocity. the simulation is also with no heat exchange and incompressible flow, so I'm using the Isothermal model. In the solution there is no entropy rise, as the Static Entropy in the Post is 0 everywhere. However, the viscosity effects in the simulation are well captured, as I obtained a total pressure distribution verified with experiments. So basically everything seems to work, but the entropy is not calculated. Do you think it's a problem?
Thank you a lot,
Giacomo
gmingardo is offline   Reply With Quote
Old   February 13, 2017, 09:49
turbo is on a distinguished road
Consider the definition of entropy : dq=Tds.
Your isothermal condition falls to isentropic.
turbo is offline   Reply With Quote
error: uninitialized local variable 't' used MASOUD Fluent UDF and Scheme Programming 5 October 17, 2016 05:24
fprint problem MASOUD Fluent UDF and Scheme Programming 5 October 30, 2011 17:08
defining a term for a domain using DEFINE_ADJUST MASOUD Fluent UDF and Scheme Programming 1 September 24, 2010 06:08
enum MASOUD Fluent UDF and Scheme Programming 0 June 5, 2010 01:49
Entropy Generation in compressible flow Dave FLUENT 0 January 5, 2004 08:12
