Meshing problems???
Old   August 8, 2000, 13:04
Default Meshing problems???
Nish
Hi All I have a problem with geometry creation. I can create a geometry for a multipler impeller stirred tank reactors. But when I try to patch the unamtched grids in my command file I get an error saying the type BLKBDY already exists. I need urgent help. Could someone who is working with stirred tank reactors contact me please.....
Old   August 10, 2000, 22:34
Default Re: Meshing problems???
pastor
......nunhez@feq.unicamp.be....can help...... t+++
pastor.
Old   August 10, 2000, 22:35
pastor
.......nunhez@feq.unicamp.br.....
Old   August 22, 2000, 03:57
jonac
Nish, I am sorry I am not here to suggest a solution for you but to make an inquiry. I am modelling a stirred tank reactor too and I would like to know your way of building an impeller. I am currently just specifying "thin surface" for both disc and blades but taking into no account of their thickness. Any information will be greatly appreciated. Thanks.
Problems of Icem meshing about Conical Forebody raja2010 ANSYS Meshing & Geometry 2 December 6, 2010 10:20
[snappyHexMesh] Problems meshing a pipe U.Golling OpenFOAM Meshing & Mesh Conversion 2 November 30, 2010 06:24
CFX meshing aspect ratio problems akash_morar CFX 3 November 13, 2010 23:41
Problems with Meshing: Collapsed Cells Emmanuel Resch Siemens 1 July 30, 2007 04:02
Problems with internal angles when meshing Ivan CFX 2 August 30, 2002 07:54
