February 9, 2017, 11:11 |
Valve Rigid Body Modelling
Rep Power: 13 |
I'm working on a valve plate simulation and want to start with and 10° wedge of a fully rotational symmetric setup. Currently, there is one rigid body in my Pre setup. This is, where the first questions arise [at this point, a little more detail in the cfx help would be nice]: 1) When I only compute 10°, my mass of the rigid body is 10 / 360 times the original one, correct? 2) The spring force - as not area dependant - should be the full constant, not scaled, correct? Thanks in advance [edit: for ease of reading] due to the fact, that my body moves, when it should not move as the driving pressure difference is much to small -> more precise: it should get pushed into its seat with the conditions applying Last edited by mo-ca; February 10, 2017 at 01:47. Reason: ease of reading |
February 9, 2017, 16:36 |
Rep Power: 144 |
I do not really understand your question - computers understand nested parenthesis just fine but it overloads a human front side bus .
If you are modelling a 10 degree wedge of a axisymmetric model with a rigid body simulation then yes, the 10 degree wedge should have 10/360 of the mass but the spring should have 10/360 of the spring constant. The natural frequency of a spring mass system is f = k sqrt(k/m). So to keep the frequency the same with 10/360 of the mass the spring constant will also need to be 10/360. |
February 10, 2017, 07:51 |
Rep Power: 13 |
thanks so far - and especially for the explanation ... I edited the first post for the ease of reading.
February 16, 2017, 11:26 |
Rep Power: 13 |
Hi again & sorry for the double post, but as this belongs to the same case, perhaps its ok to ask follow-ups.
I created the mentioned rigid body system with mass and spring as my measurable system. Now the piston moves out of the working chamber, expanding the air inside. That works so far, but when comparing measured data to simulation, the expansion is way to slow and uses a far to low pressure difference to open. As this simulation is adiabatic as well as air with ideal gas, it should be closer to an ideal expansion with lower pressure difference. [click pictures for larger version] If I put the same system into matlab, solve the ode for a simple force induced mass-spring-system, I get a reasonable lift with oscillation Has anyone experienced such things with cfx rigid body modelling? [edit] ok .. I files a service request and will share a possible solution afterwards Last edited by mo-ca; February 17, 2017 at 08:02. Reason: Matlab Update, Service Request filed... |
body, fsi, rigid, symmetry, valve |
Rigid body + remeshing error in redefining the rigid body updated-initial conditions | Pat84 | CFX | 27 | August 30, 2022 11:25 |
udf for valve closing a pipe using dynamic mesh | chem engineer | Fluent UDF and Scheme Programming | 2 | May 13, 2017 09:39 |
force and rigid body | armin najarian | CFX | 1 | August 20, 2015 13:46 |
force convergence problems in CFX 6DOF rigid body solver | ajay_ks | CFX | 8 | March 25, 2013 04:02 |
What type of boundary for a moving rigid body? | Ryan | FLUENT | 5 | April 13, 2004 11:55 |
