CFX 5.4 cannot restart with 5.3 format
Old   July 11, 2000, 03:24
Default CFX 5.4 cannot restart with 5.3 format
Bart Prast
Hi you all,
I wonder if I'm the only one with this problem: We just received our copy of CFX 5.4. We ran allready lots of runs with version 5.3 and want to use the extended physical modelling of 5.4. BUT!!!: version 5.4 can't restart with files from 5.3. It is not upwards compatible!!! apparently the data structure from 5.4 is different from 5.3. Anybody with a conversion tool?
I think this is very bad for a profesional tool.
regards,
Bart Prast
Old   July 12, 2000, 01:13
Default Re: CFX 5.4 cannot restart with 5.3 format
joecfd
Your statement is not entirely accurate.
In order to get to where you have gotten you must have read the 5.3 database into CFX-5.4 Build. This part of the process is fully compatable. From there you can create a new mesh with 5.4 build with full access to all 5.4 physics. So, your geometry and problem setup are not throw away and you can add new physics into the problem definition from there.
A more accurate statement is that you currently cannot use a 5.3 solution field, which you previously obtained, as input into the 5.4 solver when turning on new 5.4 physics. You can however, run the 5.3 results file through the 5.4 solver and it should work. This in itself entitles you to some benefits of the new 5.4 solver, such as it's increased performance for example.
I'd say let's wait and see if CFX provides a patch which remedies the real problem.
Old   July 12, 2000, 09:18
Stuart Orme
I'm not that clued up on CFX54 yet, however I've been lead to believe that you can read the results from the 5.3 model and use them as a restart for the 5.4 runs even if the geometry has changed. This is a result of the interpolation techniques used in the adaptive griding now available within 5.4. As for the effects of additional physiscs I'm not sure.
Old   July 17, 2000, 08:47
Default Upgrade to CFX-5.4 training course
Gavin Butcher
Talking of CFX-5.4, we are holding an "Upgrade to CFX-5.4" training course on 10th August here at Harwell (UK).
The course is intended for users of CFX-5.3 who wish to receive training on the new capabilities within CFX-5.4.
Please see http://www.software.aeat.com/cfx/Tra...ktraining.html
or contact me for further details.
Old   August 23, 2000, 11:32
Dan Williams
Hi All,
Along with many other fixes, a patch for this is available. It can be downloaded from:
ftp://ftp.asc.on.ca/public/patches/CFX-5.4-Solver
Just download the patch file for your system and install it. The path file readme describe all the various fixes and enhancements.
Dan.
Old   September 6, 2000, 04:18
Bart Prast
What do these fixes fix? There is no documentation anywhere.
Old   September 14, 2000, 16:05
Dan Williams
Yes there is documentation. Install the patch and select Show->All in the Launcher. There is a section entitled known patches which has what you want.
Dan.
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 03:20
CFX 4.3 vs CFX 5.3 deasyh CFX 13 February 9, 2001 21:37
CFX 5.4 Developing flow Bobby Malone CFX 4 October 4, 2000 00:27
cfx 5.4 kinematic diffusivity Daniel Gubler CFX 0 July 20, 2000 04:47
File export from CFX 5.3 Sinjae Hyun CFX 1 July 12, 2000 10:20
