Importing data from file in Ansys DesignModeler |
February 3, 2017, 18:57 |
fabio
I've been struggling with designModeler to import data from point list in a file. It kept giving me the error "Error reading coordinates file", when I finally found out that the error is some regional settings. The problem is that my Ansys recognizes decimal separator as comma, and not dot. Known that, I could import the list. But when I want some negative value (like -0,01), it gives me the error again. Does someone knows how to change these settings or, at least, how to use negative values correctly? Thank you very much P.S: I am using concept/3D curve to import the data Last edited by fabiocrj; February 3, 2017 at 18:58. Reason: fogot some information |
comma, decimal separator, negative |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 17:18 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
