How to extract the coordinates of all the mesh points along a curved edge in Ansys |
February 3, 2017, 11:07 |
Hi all,
I am using Ansys-CFX to simulate pipe flow. my fluid domain is a complicated geometry with a lot of bends and I want to plot the temperature along the center line of the pipe. However in CFX post, i am not able to create a polyline except import from a csv file. So I am wondering if I could extract a csv file of all the mesh nodes along this line from Mesh so that I could use fin the post. Does anybody know if its possible and how I should do it? Many thanks in advance. |
February 3, 2017, 22:25 |
Rep Power: 144 |
Or you could put a single streamline down the middle of the pipe, generated from a single point at your inlet. The you can use this streamline object to plot temperatures against.
You can export the mesh from CFD-Post with File/export and select the object you wish to export the mesh from. You could export you entire mesh this way if you like. Or the streamline object I described before. |
Pro/E to ANSYS Parameterization Guide | Trues | ANSYS | 4 | April 18, 2018 06:52 |
[Commercial meshers] Problems with ANSYS mesh conversion | tdog | OpenFOAM Meshing & Mesh Conversion | 1 | March 31, 2016 18:36 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 20:43 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
