Error in CFX Solver - INIT_MESH_PHYSICS - Transient Blade Row - Fourier Transf.
Old   February 3, 2017, 08:34
Default Error in CFX Solver - INIT_MESH_PHYSICS - Transient Blade Row - Fourier Transf.
TurBoris's Avatar
Bora
TurBoris is on a distinguished road
I encountered this problem (see below) after I had setup a Fourier Transformation of Nasa stage 37 transonic axial compressor at design point. I did a search on web but couldnt find anything to handle it. I conducted a steady analysis with the same mesh and it converged very well. Can you guys please help me if you have already experienced such an error. Below the problem and TBR case setup (if needed) provided.
Thanks in advance.
TurBoris is offline   Reply With Quote
Old   April 25, 2017, 14:42
Smile
Shawn Fotovati
sfotovati is on a distinguished road
Most likely you have already resolved this issue, but in case, here is what I know.
I had set the total mass flow rate with the option for area of “Total for All Sectors”. This option has no problem when the model is traditional transient. But since my case was TBR-FT transient model, CFX did not like this setting. I changed Mass Flow Rate Area option to “As Specified” and the error went away.
I hope this helps.
Good Luck.
sfotovati is offline   Reply With Quote
Old   April 26, 2017, 14:11
TurBoris's Avatar
Bora
Shawn thank you. Actually after I had encountered this, I did not spent too much time to fix it and resorted harmonic balance method in Star CCM+, but I will try what you offer as soon as possible. If it works well that willbe a good oppurtunity to compare these two methods.
Transient Blade Row - Time Transformation - Transient Details awesim CFX 17 September 8, 2022 06:23
CFX Solver stopped with error when requested for backup during solver running Mfaizan CFX 40 May 13, 2016 07:50
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 17:08
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
CFX 5.5 Roued CFX 1 October 2, 2001 17:49
