Floating point exception: Overflow ; small outlet (0.2mm)
Old   February 2, 2017, 10:53
Default Floating point exception: Overflow ; small outlet (0.2mm)
Nik Ferguson
nik.ferg is on a distinguished road
Hi CFD-Friends ,
I receive the Error "Floating point exception: Overflow" at the 13th iteration.
Here is my situation: I am simulating CO2 in a tube. The simulation works fine when the inlet is the tube diameter (10mm).
I would like to see the effects of decreasing the inlet-diameter to 0.2mm. When I do this I receive the Error I mentioned.
Sorry for the typo in the title. I mean Inlet not Outlet...
Does anyone have a solution? I already tried changing the mesh to coarse (no effect).
I would be very grateful for some help!
nik.ferg is offline   Reply With Quote
Old   February 2, 2017, 20:04
FAQ: https://www.cfd-online.com/Wiki/Ansy...do_about_it.3F
Old   February 3, 2017, 02:04
urosgrivc
urosgrivc is on a distinguished road
check what your mesh looks like at that hole.
The mesher might just left out that small circle,
you must have some elements inside that 0,2mm circle that means that you need very small elements on that face,
probably smaller than 0,1mm.
changing the mesh to coarse will only do worse, as you need fine or just face sizing of 0.1mm on that hole surface.
If you have automatic mesh based defeaturing ON I dont see why the mesher would hesh that face It obviously depends on your geometry
but i dont know what it looks like so..
Just a thought, might be something else.
urosgrivc is offline   Reply With Quote
cfx, cfx-solver, error, mesh, small inlet
icoFoam floating point exception (8) leizhao512 OpenFOAM Running, Solving & CFD 7 November 1, 2018 12:43
simpleFoam: floating point exception student666 OpenFOAM Running, Solving & CFD 9 March 13, 2016 19:23
floating point exception [invalid operation] jubair073 STAR-CCM+ 5 April 24, 2015 14:05
Floating point exception (core dumped) for GAMG solver yuhou1989 OpenFOAM Running, Solving & CFD 2 March 24, 2015 20:28
[snappyHexMesh] snappyHexMesh and cyclic boundaries Ruli OpenFOAM Meshing & Mesh Conversion 2 December 9, 2013 07:51
