Diffuser with swirling inlet flow
Old   March 20, 2000, 07:22
Default Diffuser with swirling inlet flow
Olu Bolumole
I am trying to the see the effects of a diffuser with an axial (u) plug inlet profile and rankine vortex velocity profile specified at the inletl. The grid has been generated and as far as i know is ok. The problem i am facing is that though i have specified the tangential velocity (w) profile, i am unsure how to tie it to the axial velocity (u). Basically, i am trying to write subroutines in fortran than defines the axial velocity profile from the tangential.
Old   March 28, 2000, 18:24
Default Re: Diffuser with swirling inlet flow
Jan Rusås
Dear Olu
I am not sure if I understand your problem, but you can very easy in usrbcs.f define the axial velocity from your tangential velocity, I even think there are some standard examples on using usrbcs.
Regards Jan
Wake induced inlet flow sherifkadry CFX 9 August 16, 2011 18:26
Net mass flow inlet vs outlet Nigui28 FLUENT 1 August 12, 2011 11:09
Flow Reversal at the inlet salihovic CFX 3 July 15, 2010 11:50
modelling slug flow with pressure inlet Azman FLUENT 0 May 29, 2006 07:45
Mass flow inlet B.C. at exit... Jack Keays FLUENT 2 October 6, 2000 09:39
