Using Tecplot to view CFX dumps
Old   February 10, 2000, 12:10
Default Using Tecplot to view CFX dumps
Luis R. Rojas-Solorzano
Has anybody used Tecplot to visualize CFX dump files? If so, are you willing to share the main hints?
Thanks,
Luis Rojas-Solorzano
Old   February 24, 2000, 07:11
Default Re: Using Tecplot to view CFX dumps
Andreas Ruhrmann
You can view them indirectly. If you start up cfx view, but specify "set interface parameters" you will get to the menu where you can write data files. Write the files as plot3d (binary or character). You then need to rename the output files follows:
f.dat.* to name.f
q.dat.* to name.q
x.dat.* to name.g
where name is any valid filename and must be the same for all three files.
You can then use preplot to import the files. If you use binary format, you might need to use the fortran binary option in preplot.
The variable names won't be preserved, but if it isn't possible to tell from the data, the cfx manual states how CFX exports in plot3d format.
Good luck,
Andreas
Old   February 25, 2000, 09:35
Christian COPIN
We use a program called FL3D2TEC which convert CFX dump file to Tecplot readable file This program has been developed by Peter Witt in australia I think you can join him at CSIRO Minerals email cfd@minerals.csiro.au to know if you can use it
Old   March 29, 2000, 13:00
Default Tecplot now reads Plot3D files directly
Kelly Paletta
FYI Tecplot version 7.5 and later releases include a Plot3D data loader. This data loader will allow you to load Plot3D grid, function and/or solution files directly into Tecplot without running the preplot utility. So you should be able to export your data from CFX in Plot3D format (binary, formated or unformatted) and then load these files directly into Tecplot via the Plot3D importer.
You can find the Plot3D loader in Tecplot 7.5 or Tecplot 8.0 under File/Import...
Kelly
exporting cfx file in tecplot vij CFX 8 August 18, 2011 19:43
CFX to tecplot for plotting Cp(preesure coeff.) jason_ CFX 3 June 20, 2011 19:38
PhD using CFX Rui CFX 9 May 28, 2007 06:59
CFX to Tecplot Zurayk CFX 1 January 19, 2007 11:27
Tecplot & CFX 4.4 S. H. Kim CFX 3 December 20, 2001 07:07
