How insert source term on the Rotor-37 in CFX? |
January 28, 2017, 13:12 |
mojtaba
Rep Power: 10 |
hi all,
i need to add force on Rotor-37 blade in 1/4 chord section, do you have any idea that how done this work? can i insert this as a source term? if yes, How? |
January 28, 2017, 17:04 |
Rep Power: 144 |
What is the force from? Does it act on the blade or the fluid? Are you doing FSI on the blade or is the blade rigid?
January 29, 2017, 09:19 |
Rep Power: 17 |
Are you thinking of adding flow momentum as a source term in your plasma actuator model? If yes, how are you going to define the plasma boundary that will change depending on the strength? Just go with a simpler approach in CFX.
January 29, 2017, 12:14 |
mojtaba
Rep Power: 10 |
January 29, 2017, 12:15 |
mojtaba
Rep Power: 10 |
i earn the effect of plasma previously and know want act this on the CFX
January 29, 2017, 17:17 |
Rep Power: 144 |
Then apply it as a momentum source, as turbo has already stated (and I already stated on your other thread).
Source Term due to evaporation in energy transport equation | styleworker | OpenFOAM Programming & Development | 3 | September 7, 2022 04:09 |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 04:30 |
Additional Variable Source Term in CFX | PranjalNewton | CFX | 1 | October 28, 2015 16:12 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 17:02 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
