July 10, 2014, 14:42 |
#21 |
Hesam Moghaddam
Rep Power: 14 |
However, when I change it to free slip adiabatic for top and bottom and use
domain initialization the same as the inlet. I get the attached results with the residuals moving in 1e-8 to 1e10 range and goes on until the heat transfer and turbulence converges!!!! however the heat transfer and turbulence ones seems to converge.monitor222.jpg ccl-2-1.txt CCL-2.txt Thanks |
July 10, 2014, 14:43 |
#22 |
Hesam Moghaddam
Rep Power: 14 |
July 10, 2014, 14:46 |
#23 |
Edmund Singer P.E.
Rep Power: 21 |
Ok, so what is the problem?
July 10, 2014, 14:48 |
#24 |
Hesam Moghaddam
Rep Power: 14 |
Is it ok that it is over converging?
Does it mean it is already converged in terms of momentum? SO there is nothing wrong with that? So for transient simulation, I should just change the analysis type and keep the rest as before? |
July 10, 2014, 14:50 |
#25 |
Edmund Singer P.E.
Rep Power: 21 |
Over converge? Never heard of such a thing.
Steady state is working. Transient should work just fine. I have done many of these problems. Typically I model a large caliber gun blast and blow down. Pressure wave travels just fine. |
July 10, 2014, 15:01 |
#26 |
Hesam Moghaddam
Rep Power: 14 |
It was a made up word. sorry.
I meant what does it mean when you set your convergence criteria to 1e-6 but the momentum components are converged from the beginning of the run like this case? It seems to be running for now, hopefully it won't fail. Thank you again. Best, Hesam |
July 10, 2014, 20:37 |
#27 |
Hesam Moghaddam
Rep Power: 14 |
Dear Edmund,
The flow in a channel went ok. however, back to my original problem, supersonic flow over a forward-facing step, my steady state run diverges and fails after 120 iterations. I used the same BC for this problem and just defined no-slip BC on the step surfaces. I have attached the geometry and the CCL file. I would appreciate if you could take a look. the velocity is 1041.84 at the inlet corresponding to M = 3 and the domain initialization is the same as the inlet. thanks, Hesam |
July 11, 2014, 08:57 |
#28 |
Edmund Singer P.E.
Rep Power: 21 |
I would guess that your Boundary conditions are too close to your step. For sure, a shock wave is hitting that step, reflecting back and hitting your opening.
Move the BCs further away. Also, turn on high speed numerics. its under solver control. Dont use Auto Timescale. Use a Physical One, for starters you can try L_characteristic/U, or use Local Timescale first then switch to Physical. |
Fluent and supersonic flows with strong shock waves | gera | FLUENT | 13 | December 15, 2015 06:21 |
CFX converge problem caused by shock waves | littlelz | CFX | 3 | August 17, 2009 10:35 |
Will compression waves overtake a moving shock? | GRA | Main CFD Forum | 2 | October 19, 2006 01:24 |
HELP! Shock waves not heating up... | PattiMichelle | Phoenics | 0 | December 27, 2005 13:31 |
Normal shock waves | Fernando Velasco | Main CFD Forum | 1 | April 6, 2000 15:10 |
