Hendirk
Rep Power: 10 ![]() |
Good day everyone,
i am desperately trying to extract the velocity values from the User Surface which i created in CFD-Post (as seen in the picture below: Blue -> turbine blade surface, Rainbow -> free stream velocity normal to blade surface) I need the free stream velocity normal to the turbine blade surface to calculate the acceleration parameter K. Or is there a way to get it directly in fluent or any other way? Thank you for your help, its highly appreciated. |
Hendirk
Found the Solution myself, did not see that coming.
in CFD-Post go to File->Export->Export...-> Locations: Select the location you created. Down below you can select the requiered variables. Excel or a similar program can open the obtained .csv file |
how to calculate water average velocity in free surface models | hmasenger | CFX | 22 | October 30, 2019 20:28 |
How to prescribe fixed values of velocity and fixed temperature raise | Petrz | FLUENT | 1 | March 11, 2015 13:50 |
How to calculate velocity at a interior surface? | wanghaojie | Fluent UDF and Scheme Programming | 0 | March 23, 2012 11:21 |
Ansys FLUENT UDF - Velocity profile (of known values) across edge / surface | emmkell | Fluent UDF and Scheme Programming | 2 | October 21, 2011 14:12 |
CFX 5.5 | Roued | CFX | 1 | October 2, 2001 17:49 |
