Measure active temperature in point, body or surface |
December 21, 2016, 08:17 |
Jakob Lindqvist
Rep Power: 10 |
Hello!
I just registered on this forum as I am going to do lots of work now and in the future in my studies. I am new to ANSYS CFX and this may be a small question to ask in an entire new thread. The problem: I want the mean temperature in a solidified body of air and make the assumption that the air in another body is 10 °C lower somewhere else. This because I have to assume a convective heat loss from the model which is dependent on a temperature somewhat lower than within my geometry which is a small area of the big surveillance pod we're simulating. How do I make an expression of the temperature in a certain point or mean body temperature which I can use in the boundry condition on the outer surface? I need an outside temperature along with my heat transfer coefficient. Furthermore, where can I find syntax for ANSYS to get these, probably already implemented funcitons in ANSYS? I'm quite new to this and the question might be stupid but I'm glad for all the help I can get. Regards Jakob |
December 22, 2016, 06:12 |
#2 | ||
Rep Power: 144 |
You seem to be asking how do you set a temperature to be a function of a temperature somewhere else - in concept this is easy, just set a CEL expression to abc = voluemAve(t)@Region, and then set the wall temperature of the other surface to variable abc. But I think you will find this is numerically unstable and will require additional treatment to converge. But more importantly, this does not sound physically realistic, and physically unrealistic things are always very difficult to converge (because they are impossible ). So I recommend you think about what is really happening here. Or if you want us to help you work out a better way of modelling it please explain what you are doing more fully. Include images and a description of what it does - and why you think the temperature of one region is linked to the temperature somewhere else. |
December 24, 2016, 06:12 |
#3 | |
Jakob Lindqvist
Rep Power: 10 |
The trapped air acts like a solid, only conduction is modelled. But the air which is not trapped is to assume a temperature. Because the volume of this air is bigger and because the convection maybe could be neglected on these surfaces we just want to approximate the temperature in this air to make an expression for the convection. And the only thing I can tell is that it should be lower than the trapped air. To make convection I need a temperature difference. Thanks for volumeAve! It solved the problem. Also found more functions in the meny in ansys really convenient Last edited by StudentinANSYS; December 24, 2016 at 10:11. |
December 24, 2016, 07:01 |
Alex
Rep Power: 49 |
A hint for further questions: a sketch is worth a thousand words. Literally
December 24, 2016, 10:28 |
Jakob Lindqvist
Rep Power: 10 |
December 25, 2016, 05:04 |
Rep Power: 144 |
To back up Alex's comment - after reading your description in post #3 I am even more confused.
Why is the switch going at Mach 2? That does not seem normal switch behaviour And what do you mean by trapped air acts like a solid? Please attach an image of what you are trying to do. Here is the way to attach an image: https://www.cfd-online.com/Wiki/Ansy...n_the_forum.3F |
December 30, 2016, 08:38 |
#7 | |
Jakob Lindqvist
Rep Power: 10 |
Acknowledge it is really simple and out of proportions. According to Holman J.P, Heat transfer 10th edition, 2010 trapped air can be modeled as a solid if a new effective k-value is calculated according to the circumstances. This is also confirmed by our professor. Mach 2 is the speed the pod is required to function during flight mounted on a SAAB GRIPEN. As we're not modelling the entire pod I had to estimate an air temperature for the air underneath the topmost box mounted on the inside of the pod's frame. As it doesn't heat flux much from the inner frame of this box to the inside air in the pod (the temperature is about the same here as inside the box of the power converters) I just wanted to estimate it somewhat and therefore used volumeave(T)@inside air in box and subtracted 10 instead of neglecting it. The mechanical attachment to the frame of the pod is acting as a heat sink and is transporting most of the heat out of the power switch. The convection on this surface is really high and is cooling it off efficiently. |
December 31, 2016, 04:48 |
Rep Power: 144 |
I still have little idea of what you are modelling. The image is very simple and is not labelled.
From what I can guess you are doing: Your assumption that the trapped air can be modelled as a constant temperature rise compared to somewhere else sounds very dodgy. Why not just model it as adiabatic? Or why not model it as normal air anyway? |
January 14, 2017, 11:19 |
#9 | |
Jakob Lindqvist
Rep Power: 10 |
http://imgur.com/a/sb5zU these are some result. Temperature will always be the same as I am stopping sims at a given qualification temperature, just interested of the time the pod can run. Estimating it around 30 minutes with different elevated temperatures /Jakob |
January 14, 2017, 18:13 |
#10 |
Rep Power: 144 |
Can you please imagine you are explaining this to your grandmother. But only that your grandmother happens to have a reasonable amount of general experience in CFD . I have no idea what the pod is, where the outer frame is, where the power switch is, or why convection is relevant. Also I have no idea what relevance the qualification temperature is or how this relates to how long the pod can run.
I suspect at this stage is that the originally posted question is an XY question (http://xyproblem.info/) and that the correct approach for this is totally different. But as I don't have much of an idea of what is being proposed in this thread I can't suggest anything useful yet. |
January 15, 2017, 10:12 |
#11 | |
Jakob Lindqvist
Rep Power: 10 |
I'm qualificating an electrical system on what temperatures it should withstand. The warmest part is the power switch. It has to be designed to withstand the temperature I figure out according to an initial stabilized outside temperature. After recieving the critical temperature in the power converters in the switch, I run it at elevated temperatures as an sensitivity analysis to check how long it can withstand running if it flips from idle to load. |
January 15, 2017, 14:55 |
#12 |
Rep Power: 144 |
Thanks. So why not just use a normal cht simulation with an air domain with no special treatment, just flowing past at mach 2 on the outside and mixing and connecting inside the device?
cfx 17.1 |
heat transfer coefficient value in floefd | jason kid | FloEFD, FloWorks & FloTHERM | 10 | October 16, 2016 17:55 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 16:03 |
how to get surface temperature of pipe at cross section using iso-surface | ashgun | FLUENT | 8 | June 2, 2013 03:03 |
[blockMesh] error EOF in blockMesh | Ahmed Khattab | OpenFOAM Meshing & Mesh Conversion | 7 | May 17, 2012 01:37 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
