Mixing plane with implicit averaging (beta feature) |
December 19, 2016, 16:53 |
Rep Power: 11 |
Hi all,
I'm currently running single passage simulation of a transonic turbine. At the stator TE there're strong oblique shock waves travel towards the following blade row; however, since the stator and the rotor are closely spaced the mixing plane seems to reflect the pressure waves coming from upstream. I then run single blade row with an outlet extended downstream, and was able to have a non-reflecting exit BC and get a more physical flow field. I also tried the implicit averaging options but they didn't seem to kill the reflection. The pressure decay option didn't help either. Could anyone advise what'd be a good strategy to reduce the impact of reflection in CFX? Thank you. |
mixing plane causes fatal error | amin.z | FLUENT | 1 | October 27, 2023 08:14 |
problems with mixing plane | dowlee | OpenFOAM Running, Solving & CFD | 6 | September 21, 2016 01:14 |
mixing plane vs frozen rotor | feafan | STAR-CCM+ | 5 | August 25, 2014 07:14 |
MFR and mixing plane boundary . | Mica | Main CFD Forum | 0 | January 26, 2007 10:40 |
mixing plane in CFX5.5.1 | joseph | CFX | 1 | April 17, 2002 19:09 |
