Setting up inlet boundary condition for a pulsatile flow |
December 16, 2016, 15:12 |
Anon Anon
I am carrying out a fluid structure interaction analysis as a result of a pulsatile flow through an artery using ANSYS CFX and Mechanical.
At present I am trying to set the inlet boundary condition using the equation for Womersley number. I have so far set the following expressions in ANSYS CFX setup: Diameter = 0.033 [m] Viscosity = 6.2e-6 [m^2/s] pulsefrequency = 0.9 Hz Womersley number = (diameter/2)*((viscosity/pulsefrequency)^(1/2)) So when I go to insert a boundary condition and select an inlet boundary condition, I am wondering how can I use this expression? Under boundary conditions I set my flow regime as subsonic, the mesh motion as stationary however under mass and momentum I can only input conditions relating to velocities as far as I can see. I am a relatively new user of ANSYS so any step by step instructions on how to overcome this issue would be very useful. Thanks in advance. |
December 20, 2016, 02:55 |
kastarkas
Rep Power: 10 |
Right click the space at the inlet BC and you will find the expressions tab and select your expression
cfx, expressions, inlet boundary condition, pulsatile flow |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
Total pressure and mass flow boundary condition at inlet | bscphil | OpenFOAM Pre-Processing | 3 | July 9, 2017 15:39 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 09:44 |
To change temperature in mass flow inlet boundary condition per iteration | ajinkya201991 | FLUENT | 1 | July 11, 2014 12:29 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
