Temperature results node by node
Old   December 7, 2016, 08:55
Default Temperature results node by node
Jarda Chlup
Jared1986 is on a distinguished road
Hello to everybody, I have question concern to calculating and setting boundary conditions directly to each node for separate domain. I'd like to know If it is possible to set and change boundary condition for each mesh element based on temperature measured on that element? Thanks a lot for answer...
Jared1986 is offline   Reply With Quote
Old   December 7, 2016, 10:47
Antanas is on a distinguished road
There's no such built-in functionality. You should utilize User Fortran.
Antanas is offline   Reply With Quote
Old   December 7, 2016, 14:05
Erik
evcelica is on a distinguished road
Maybe I'm misunderstanding something, but it seems you could do this by just making the boundary condition a function of temperature. It will then be applied to each node based on local temperature.
For example,
Create and expression: HeatGen = (HeatGenFunction*Temperature)[W/m^3/K]
Or a user function where you have a table of temperature and boundary values.
Then insert that in as a source or subdomain: MyHeatGenFunction(T)
evcelica is offline   Reply With Quote
[ICEM] Error in mesh writing helios ANSYS Meshing & Geometry 21 August 19, 2021 15:18
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
monitoring point of total temperature rogbrito FLUENT 0 June 21, 2009 18:31
Constant temperature results lost.identity CFX 4 June 12, 2009 17:04
Exporting temperature results fro fluent to Ansys vinay kulkarni FLUENT 1 February 21, 2007 04:31
