My radial inflow turbine
Like Tree1Likes
Old   December 11, 2016, 20:14
Ahmad Hari
Abo Anas is on a distinguished road
Hi Brian,
1- the flow direction was based on Turbo comment. Since the axis of rotation is Z, I set x = - 1, y = tan (78.33) and Z= 0. I doubly I have a problem here
2- yes the efficiency was calculated by Rital (Comcept NREC). In Rital, I designed a turbine with volute and rotor ( no stator). So, the enthalpy drop should take place at the rotor.
Abo Anas is offline   Reply With Quote
Old   December 12, 2016, 08:20
turbo is on a distinguished road
Why did you use the compressor template in performance?
Post a 3d streamline view.
turbo is offline   Reply With Quote
Old   December 12, 2016, 09:03
Ahmad Hari
Hi Turbo,
I'm not using compressor template. I'm using turbine rotor template but I don't know why it appears as a compressor. Attached is the screenshot of the velocity streamlines
Old   December 12, 2016, 09:49
Before trying any CFD, bear in mind that you need to study the basics of turbomachinery, especially the velocity triangle.
Your geometry setting needs a negative rpm. There will be more to fix other than that. Just study setting aside the CFD job.
This forum is not aiming for providing turbomachinery education, as I know.
Old   December 12, 2016, 11:08
Ahmad Hari
That's correct but I would be happy if you mentioned "the more things need to be fixed" though
Old   December 12, 2016, 18:42
turbo4life
bparrelli is on a distinguished road
Based on the picture, rpm needs to be negative. Also, your inlet flow direction needs to be in the same direction as the rotation. Based on the axes you have, I think you need z=0, y=-1 and x = tan(78). I would strongly recommend reviewing this resource if you need a turbomachinery reference: https://www.google.com/url?sa=t&rct=...feI6rXhjuNutww
Turbo is correct. You need to review the basics of turbomachinery so you can troubleshoot your CFD. Chapter 8 of this resource is for radial turbines, but there is a good general review in the first few chapters as well. Best of luck!
bparrelli is offline   Reply With Quote
Old   December 13, 2016, 11:17
Ahmad Hari
Dear Brian, Turbo and all,
Thank you for your comments and advices. I'll keep working on that till it is fixed.
Brian,
Using the flow direction you mentioned (z=0, y=-1 and x = tan(78).), I got the following error:
ERROR #002100024 has occurred in subroutine ASS_FLX_BDINIP. |
| Message: |
| The specified flow direction on boundaries must not be tangential |
| to the boundary. However, on the boundary patch |
| R1 Inlet |
| a specified flow direction having an angle of 6.2 degrees |
| was found, which the solver considers as being nearly tangential. |
| Please do one of the following: |
| (1) Check your direction specification on this boundary. |
| (2) Set the 'Flow Direction Linearisation' to 'Velocity Magnitude' |
| in your boundary specification. |
| (3) Modify the solver tolerance by decreasing the expert parameter |
| 'tangential vector tolerance' below its default of 10 degrees.
I will try to follow the comments suggested by CFX
Thanks again all of you
Old   May 11, 2018, 02:44
SHUJAN
MDSHUJAN is on a distinguished road
Originally Posted by Abo Anas View Post
Continue of the attached photos
Just to let you, I'm using Cartesian coordinates based on comment by Turbo. I have a swirl angle (absolute flow angle) = 78.33 deg
Many thanks in advance
Anas. Hi. Have you solved your issues. I need to do similar simulation and I only have 2 days to work on it. Please, can you reply.
MDSHUJAN is offline   Reply With Quote
Interface model for a radial inflow turbine kelinjose CFX 2 February 28, 2013 14:00
Spatially and time varying inflow - turbine simulation Alex_S FLUENT 4 July 19, 2012 03:45
CFX application to radial inflow gas turbine Chetan Mistry CFX 5 June 2, 2007 14:13
radial inflow turbine rotor periodicity problem Nanda FLUENT 1 July 17, 2006 15:52
radial inflow turbine rotor periodicity problem Nanda FLUENT 0 July 11, 2006 21:35
