December 6, 2016, 11:55 |
distance between two points in CFX Pre
David Marguc
Hi, is it possible to measure the distance between two points in CFX Pre?
I inserted a new expression: probe(Axial Distance) @ <Location> But when I try to evaluate the expression ist says: "ERROR Attempt to evaluate the CEL callback function 'probe'. Although it is valid to create an expression that uses such a function, the preprocessor does not support its evaluation." Do I need to insert Coordinate Frames? Can I measure the distance between Coordinate Frames? Thank You very much!!! |
December 6, 2016, 13:19 |
#2 | |
Rep Power: 18 |
December 6, 2016, 13:38 |
turbo4life
Rep Power: 10 |
Have you tried probe(x)@<location> instead of Axial Distance? Try using one of the default spatial variables (x, y, or z). I think the variable "Axial Distance" only works once you have initialized the flow-path in Turbo mode in CFD-Post.
December 6, 2016, 13:54 |
Rep Power: 18 |
Won't work (in Pre) either.
December 6, 2016, 13:55 |
turbo4life
Rep Power: 10 |
December 7, 2016, 00:42 |
Rep Power: 18 |
December 7, 2016, 03:50 |
Lance
Rep Power: 22 |
I dont think there is a way to measure distance between two points in Pre. But this will work: load the mesh into Post, create a line between the two points and then create this expression: length()@Line 1
December 7, 2016, 11:57 |
turbo4life
Rep Power: 10 |
CFX Pre not importing Mesh | ajhunte | CFX | 10 | October 31, 2022 17:52 |
only 1 of many named selections not showing up in cfx pre | mihirbhagat | CFX | 2 | April 26, 2019 05:56 |
CFX pre error in assigning material to the domains | madan | CFX | 1 | February 18, 2015 02:55 |
define a parameter in cfx pre and use it in design modeler | OmidOmid | CFX | 3 | December 3, 2014 10:09 |
CFX - Monitor points - Automatic Export csv | nasir | CFX | 6 | November 11, 2011 22:52 |
