Hyojeong Lee
Rep Power: 9 ![]() |
Hi, guys.
I'm doing a simulation of ventilation including some fans. Fan performance curve is a table of velocity vs pressure in the form of user function. And it is implemented on a interface as a pressure change model. However, the result doesn't correspond to the value of user funtion, slightly lower. I think it is well converged. (Residuals, monitoring points and Imbalnces are resonable to assume that it is converged.) Could you suppose another point that I should check about the problem? And I wonder the "pressure" means static pressure in Pressure change model. Thank you! |
Rep Power: 7 ![]() |
Hii I am also facing the same situation. Did you solve it?
How to build current blower fan model in Flotherm | eric0722 | FloEFD, FloWorks & FloTHERM | 3 | January 2, 2021 02:36 |
Fan simulation with inlet and outlet duct for finding fan curve | chaudhry_hashim | FLUENT | 0 | August 6, 2014 10:49 |
How to define fan performance curve in CFX using interpolation function? | atulpat | CFX | 6 | January 1, 2014 07:42 |
Radial fan problem : Attn Razvan and all | Farhath | FLUENT | 0 | September 26, 2007 04:18 |
Problem With User-Defined Fan Model Panel | neihad | FLUENT | 0 | November 25, 2001 17:21 |
