SceneGraph.dll problem when running RSM on CentOS
Old   November 18, 2016, 03:39
Default SceneGraph.dll problem when running RSM on CentOS
Lukasz Miroslaw
Lukasz is on a distinguished road
Send a message via Skype™ to Lukasz
Hi All,
We are running RSM locally. RSM submits the simulations to the cluster in the cloud (with CentOS, Ansys 17.1, PBS Pro, Intel MPI). CFX simulations work well in such a setup. However, when we are running design points -based simulation we get the error:
[ERROR] Failed to load addin Ans.SceneGraph.SceneGraphAddin from location /share/data/software/ansys_inc/v171/Addins/SceneGraph/bin/Linux64//Ans.SceneGraph.dll. This addin will be skipped.: SceneGraph.Components.dll
System.DllNotFoundException: SceneGraph.Components.dll
In this folder there are following libraries available:
-r-xr-xr-x 1 hpc hpc 543232 Apr 1 2016 Ans.SceneGraph.dll
-r-xr-xr-x 1 hpc hpc 58368 Apr 1 2016 Ans.SceneGraph.Interop.dll
-r-xr-xr-x 1 hpc hpc 4375582 Apr 1 2016 libSceneGraph.Components.so
and then this error appears:
[FATAL] Unexpected error: CommandFailedException: Unable to load project '/share/data/ansys_projects/uvux7md9.hfx/impellerTest.wbpj': Ansys.Core.Persistence.ContainerLoadFailedExceptio n: An exception was thrown by the type initializer for Ansys.UI.Graphics.Diagnostics ---> System.TypeInitializationException: An exception was thrown by the type initializer for Ansys.UI.Graphics.Diagnostics ---> System.Runtime.InteropServices.COMException (0x8000ffff): Failed to create object d00ef79d-1541-4efb-814d-ba543ef7e549
Any hint how to solve this problem will be appreciated. Maybe incompability with CentOS is a problem since ANSYS does not support this Linux Distribution ? Should we then recompile the SceneGraph library?
Best regards,
Lukasz
Lukasz is offline   Reply With Quote
Old   November 29, 2016, 08:16
Maxim
-Maxim- is on a distinguished road
Hi Lukasz,
I can't help you with your specific problem but give a quick note about my experiences with CentOS and RSM. I set that up so that I can send jobs from workbench (windows) to my little cluster (centOS). It worked most of the times but sometimes it would freeze up or cancel the simulation with no explanation. Furthermore, I would lose synchronization in SolverManager with the calculation on CentOS often. The SolverManager just would not get any more data from CentOS.
Pretty useless. I am starting jobs via command line now - at least that works as promised...
Oh - my Ansys dealer/support guy said that they usually use CentOS since that works best with Ansys. Better than ubuntu etc.
-Maxim- is offline   Reply With Quote
ansys 17.1, cloud, rsm
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 20:12
ANSYS Licensing Problem, Processes Running but Showing as Not Running penguinman ANSYS 3 September 27, 2016 14:30
[Other] Problem running after decomposition paul.m.edwards OpenFOAM Meshing & Mesh Conversion 0 January 14, 2015 13:55
Problem running cavityGrade Tutorial CFDMike OpenFOAM Running, Solving & CFD 0 September 23, 2010 08:46
Problem with running FoamX in a distributed environment susana OpenFOAM Pre-Processing 1 March 28, 2007 18:11
