cfd post average of multiple planes into single plane |
November 14, 2016, 10:54 |
Ruud Caljouw
Rep Power: 14 |
Hi All,
I am modelling a free surface flow in a channel. In cfd post I would like to plot the height average of the velocity into a single plane. So the result would be a single plane perpendicular to the bottom of the channel that shows at each location the average velocity over the water column Anyone know how to do this? Thanks |
November 14, 2016, 17:03 |
Rep Power: 144 |
Please define "Height average velocity"
Also show an image with which planes you wish to show. |
November 15, 2016, 05:33 |
Ruud Caljouw
Rep Power: 14 |
So I am modelling a free surface flow out of a channel into a reservoir. Water depth in this case is 6 meter. xy plane is horizontal. z is in vertical direction, i.e. from bottom of channel upwards
On the first image you can see the velocity field in the channel and the reservoir. I plotted 3 planes at different heights from the bottom On the second image you can see the VOF, which is a sideview (y direction) of the first image What I would like to calculate is the average velocity over the water column at every x,y postion. In other words. At every x,y position in the channel and reservoir you would be able to make a vertical (z direction) line plot showing the velocity profile from the bottom to the surface. I would like to have the average of this profile and then at every x,y position shown in a single plane |
November 15, 2016, 05:47 |
Rep Power: 144 |
I cannot see how to do this in CFD-Post. I would recommend trying tecplot, ensight or fieldview as they are more powerful post-processors which should be able to do things like what you are requesting.
November 22, 2016, 03:19 |
Ruud Caljouw
Rep Power: 14 |
thanks, I got this working in Ensight, though I find the software a bit of a struggle. I will try tecplot as well.
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
Post processing in CFD Post or Fluent. | Blobs | OpenFOAM Post-Processing | 2 | June 26, 2016 08:23 |
CFD Online Celebrates 20 Years Online | jola | Site News & Announcements | 22 | January 31, 2015 01:30 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 13:21 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 13, 1999 00:27 |
