LogNormal Particles Size Distribution for Spray Simulations |
November 7, 2016, 17:16 |
Rep Power: 20 |
I am doing the Spray Simulations of GDI Engine in CFX and for that i need to provide some estimate of the particles size distribution. The particle size data which is available to me is Lognormal PDF(Probability density function) data for particle sizes as shown in the attached image. But in CFX the options which I could find are "Normal in Diameter by Number or Normal in Diameter by Mass" so these options don't fit my data as they will generate Normal distribution. I am wondering if there is a way in CFX to specify the lognormal PDF data in the text file? or does anybody has any other solution to this problem. Any help would be appreciated. Thanks in advance. Regards |
November 7, 2016, 17:36 |
Rep Power: 144 |
The options I see in V17.2 are:
* Specified Diameter * Uniform in Diameter by Number * Uniform in Diameter by Mass * Normal in Diameter by Number * Normal in Diameter by Mass * Rosin Rammler * Nukiyama Tanasawa * Discrete Diameter Distribution Hopefully you should be able to fit one of those options to your required distribution. Also note that the "Normal in diameter by mass" option will not give a normal distribution when viewed by number. You would have to calculate what distribution this gave when viewed by number, but it may be close to your required distribution as well. |
November 7, 2016, 18:01 |
#3 | ||
Rep Power: 20 |
Do you or any other any body has idea about the parameters of Rosin Rammler and Nukiyama Tanasawa distributions. The Injector has six holes with a hole diameter of 0.193mm and fuel(iso-octane) is injected into the domain at 10MPa pressure at mass flow rate of 0.0136667k kg/s. Any help would be appreciated. Regards |
November 7, 2016, 18:07 |
Rep Power: 144 |
CFX does not have a lognormal distribution built in so you won't find a "click the button" option to do what you want. You are going to have to look at the distribution shapes of the available options and adjust them to get something similar to your intended distribution.
So I would look at all the options and see what distributions they give. The lognormal distribution is a reasonably simple distribution so you should be able to get something to be close enough that the difference is not important. All I can suggest is that the "Normal in diameter by mass" option, also Rosin Rammler, Nukiyama Tanasawa and Discrete Diameter Distributions are the ones I would look at more closely. They all have several tunable constants so you are going to have to play with them to see what fits the best. |
[ICEM] Help with fixing imported IGES model | siw | ANSYS Meshing & Geometry | 24 | August 24, 2010 12:22 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 15:37 |
Plot particles w. correct size? | Michael B | CFX | 1 | August 8, 2006 03:36 |
particle size distribution | Felix | CFX | 0 | May 29, 2006 05:16 |
how to make particle size distribution | adma | CFX | 0 | January 10, 2006 16:57 |
