November 2, 2016, 15:07 |
what is the right pitch change option?
Alex
Rep Power: 10 |
Hi to all!
Can anybody give me advice what is correct choice for rotor-stator interface if rotor blades number is twice more than stator vanes one? I suppose the stage model is the right choice, but is there any differences between automatic, value and specified pitch angles options? May be any snake in the grass? P.S. About task: 7-staged axial compressor, turbogrid mesh, steady-state case. Using stage/automatic angles options, the only robust solution was yielded by massflow&temperature at inlet and static pressure at outlet combination, although the result is invalid - high pressure values (about *1.5) and low efficiency (about /1.5)... |
November 14, 2016, 03:45 |
Alex
Rep Power: 10 |
Specified pitch angles option leads to solver fail every time. Only automatic one works relatively well, I don't know why.
BC combination p*in - p out leads to solver fail, hence I have to use Gin - p out. If I find out something else, I jot down a comment. |
Simple piston movement in cylinder- fluid models | arun1994 | CFX | 4 | July 8, 2016 03:54 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 18:00 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 18:30 |
Setting rotating frame of referece. | RPFigueiredo | CFX | 3 | October 28, 2014 05:59 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 01:00 |
