variable pitch vertical axis turbine mesh motion
Old   October 29, 2016, 16:48
Default variable pitch vertical axis turbine mesh motion
Ruud Caljouw
bolus13 is on a distinguished road
Hi All,
I am modelling a variable pitch vertical axis turbine in a channel in cfx.
The model is setup in such a way that the turbine and the blades can both be modelled in circular rotating domains. This works well with moving meshes in cfx. See attach image for an impression.
The downside of the current moving mesh is that the turbine diameter can not be increased beyond the current size, otherwise the circular domains will intersect with the wall. This does not seem to work.
Would anyone know how to alter the mesh model, such that a larger diameter turbine can be modelled inside the channel where the blades move closer to the wall.
may thanks
bolus13 is offline   Reply With Quote
Old   October 30, 2016, 18:35
You can edit meshes in ICEM and many other meshing software (GridGen etc).
But it is usually much better to go back to the original geometry, fix the geometry and remesh. This is usually much easier than editting and existing mesh.
Old   October 31, 2016, 04:39
Ruud Caljouw
So, in a transient run I would change the geometry and remesh at each time step?
That sounds logical to me. Do you know if this something that can be done in workbench? This is what is generally work with.
Old   October 31, 2016, 06:18
I may have misunderstood your question. I assumed you were talking about changing an existing mesh for a new geometry. You seem to be talking about dynamic remeshing during a run.
Can you explain what you are trying to model and what the motion you expect is? Also, where does the motion come from?
Old   November 1, 2016, 04:51
Ruud Caljouw
I am modelling a vertical axis turbine inside a channel. The flow is driven by a pressure difference over the channel. Normally I would use standard methods, as frozen rotor and transient stator rotor.
In this case the blades have variable pitch. The guys at ansys gave advice to setup the model using nested rotating domains and moving meshes. In the picture I added in the first post you should be able to see the rotating domain of the turbine and the nested domains of the blades.
The simulation works well for this scenario, since I can use circular domains. Problem is that I can not make my turbine diameter larger, since the nested domains around the blades will interfere with the wall. In this case the nested domains can not be circular anymore.
I am unsure how to proceed, but a solution could be to change the geometry and remesh at each timestep. It is something I have not done before.
Any advice on how to proceed
Old   November 1, 2016, 17:49
There are tutorials on remeshing on the ANSYS customer website.
Why not just make the rotating domains a little larger than the can handle the additional motion without problems?
intersect wall, moving mesh, pitch, vat
Vertical axis water turbine simulation SHIKHA BHUYAN ANSYS 0 September 16, 2014 02:06
Vertical axis water turbine simulation SHIKHA BHUYAN CFX 1 September 15, 2014 08:40
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
Modeling a rotating vertical axis stream turbine VIMeerkat FLUENT 0 February 11, 2013 14:03
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
