Error in Chapter 18 Gas liquid flow in an airlift reactor
Old   October 28, 2016, 03:14
Post Error in Chapter 18 Gas liquid flow in an airlift reactor
Ji Guozhao
jiguozhao is on a distinguished road
Hi Guys,
I am following the CFX tutorial Chapter 18: Gas liquid flow in an airlift reactor.
What I set was exactly the same as all the settings in this tutorial. But when I run the def file to solve. The following error keeps coming up.
| ERROR #001100279 has occurred in subroutine ErrAction.
| Message:
| Floating point exception: Zero divide
| Message:
| Stopped in routine FPX: C_FPX_HANDLER
How can I get through this tutorial?
Any suggestion is welcome.
Thanks All!
Cheers
Guozhao
jiguozhao is offline   Reply With Quote
Old   October 28, 2016, 06:14
There is something you have missed. All the tutorials have been extensively tested.
Old   October 28, 2016, 07:37
Ji Guozhao
I tried again and again. The error is still there. Would you please judge which part I missed based on the error showed?
Old   October 28, 2016, 07:52
You could run the .pre file and generate it that way. Then compare the CCL of that .def file to the CCL of the .def file you generated. You might be able to spot the error that way.
Old   October 28, 2016, 08:23
Ji Guozhao
Thanks so much. I was thinking the same way when I found the pre file in CFX example folder. But would you please indicate me how to use the pre file in CFX?
Old   October 30, 2016, 18:27
Open CFX-Pre and select Session/open session.
Old   October 31, 2016, 06:29
Ji Guozhao
Thanks, it works well.
tutorial18
error message cuteapathy CFX 14 March 20, 2012 07:45
Need advice on softwares working for dilute gas flow Mason Main CFD Forum 4 July 22, 2010 16:55
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Liquid/ Gas flow with VOF rt FLUENT 0 May 11, 2006 03:17
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
