Calculating massflowrate of a Centrifugal fan |
October 27, 2016, 16:43 |
Yavuz Selim Mehel
Rep Power: 10 |
Hi everyone,
My question is; I have a centrifugal fan and I want to calculate its massflow rate and maximum total pressure for a given rotational speed using CFX. What should I enter as boundary conditions? I can't give massflow for inlet or outlet as boundary condition because I don't know it. Could you help me please? Last edited by mehelyavuzselim; October 28, 2016 at 05:54. |
November 1, 2016, 11:48 |
Jarda Chlup
Rep Power: 13 |
Hello, If I understand clear, you want to know fan curve. Pressure on one axis and volume flow on the other axis. You should try to set few points for your calculation. First you should choose right direction of rotation, if you don't have straight blades (90degree angle)... Next step is setup of low mass flow rate on the outlet and 0 Pa on inlet side. You obtain value of pressure close to highest value of the total pressure and after that you can try to set next value of mass flow rate and as soon as you obtain different polarity of the pressure, you will have value close to maximum of mass flow rate. I hope that this answer will help you. Good luck
November 4, 2016, 13:24 |
Yavuz Selim Mehel
Rep Power: 10 |
First of all thanks for your reply. Actually I want to only calculate maximum massflowrate and maximum total pressure for a given rpm. In your method, I have to run 4-5 different boundary conditions to get max flowrate. Is it possible to do it with 1 run? |
November 5, 2016, 08:24 |
#4 | |
Rep Power: 11 |
Create a monitor in CFX pre (Output control) printing MFR and TotPressure at the boundary of your interest. The expression for the MFR is MassFlow()@Boundary and total pressure is MassFlowAve(Total Pressure in Stn Frame)@Boundary. You can get the maximum for a transient run in the solver monitor when running the solution (or the steady state converged value) |
November 9, 2016, 07:20 |
#5 | |
Yavuz Selim Mehel
Rep Power: 10 |
November 10, 2016, 09:15 |
sluzzer
Rep Power: 12 |
The maximum flow depends on the maximum pressure ratio at which the fan will not stall.
So run by setting different value of pressure ratio as boundary condition (assume the values). As you keep on increasing the pressure ratio, the change in mass flow rate will keep on reducing and it will become asymptotic. That's the point of maximum mass flow rate which is near the stall point. Further increasing the pressure ratio will induce stall and you cannot solve that in steady state condition. If you want then you can run the transient simulation and confirm. Then you can, your centrifugal fan gives a maximum of flow of X at the applied pressure ratio or difference of Y and at the applied speed of Z. Hope you understand |
November 10, 2016, 13:01 |
#7 | |
Yavuz Selim Mehel
Rep Power: 10 |
Frozen rotor domain RPM will be constant. Fluid domain reference pressure will be 1atm. As boundary condition first I will try to give Total Pressure (TP)=300 Pa, for Total Temperature (TT) 20°C. These were for the inlet BC. For outlet BC I will give static pressure 0 and run it. After run finishes, I will calculate the flowrate. Then in the second step I will give inlet BC TP=350 Pa and TT=20°C, for outlet BC Static pressure=0 Pa and I will run it. After run finishes I will calculate the massflow rate. I will repeat these steps till flowrate almost does not change. Right? Last edited by mehelyavuzselim; November 10, 2016 at 14:13. |
How to build current blower fan model in Flotherm | eric0722 | FloEFD, FloWorks & FloTHERM | 3 | January 2, 2021 03:36 |
Centrifugal fan as a momentum source | siw | CFX | 3 | August 20, 2015 06:48 |
Modeling of centrifugal fan in CFD | Simon Williams | Main CFD Forum | 3 | February 20, 2009 16:00 |
How to model flow of centrifugal fan? | Peter | Main CFD Forum | 0 | April 2, 2008 07:07 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 18:27 |
