Jordi
Rep Power: 0 ![]() |
I'm a completely new CFD user going through the tutorials in order to learn to simulate flow on hydrofoils. As far as I understand I can set the default pressure to 1 atm, normal speed at inlet and relative pressure on the outlet to 0 or relative pressure where is venting. Could anyone explain why is Ansys setting the Outlet pressure to 51957 ? Are they assuming the foil is submerged enough to have that pressure? |
Rep Power: 144 ![]() ![]() ![]() ![]() |
No, the example sets the reference pressure to 0 and the outlet is 51957 Pa. For the initial no cavitation model this makes no difference as the model is incompressible. But in the second model with cavitation it will affect the cavitation as cavitation uses absolute pressure.
I do not understand why this is done - this means the system is running at vacuum of about half an atmosphere and is more prone to cavitate. But I guess it could be simple as - if you run this at atmospheric pressure it does not cavitate nicely, so they lowered the pressure to get a clearly defined cavitation region. |
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC | Endel | OpenFOAM Running, Solving & CFD | 3 | September 11, 2014 16:29 |
pressure outlet condition setup | halfblood@SYSU | Main CFD Forum | 0 | March 15, 2013 22:35 |
Pressure outlet BC help! | eishinsnsayshin | FLUENT | 7 | December 3, 2012 23:36 |
Unsteady pressure differential between inlet and outlet of the pipe for single phase | joshi20h | FLUENT | 0 | September 26, 2012 12:41 |
Pressure Outlet setting | CoG | STAR-CCM+ | 4 | June 9, 2010 21:47 |
