Rep Power: 10 ![]() |
Does negative mass flow rate across a surface mean the fluid is flowing out from domain?
Alex
yes, in whole it is. Some streamlines can get into domain though
Thank you very much, Red Ember :-)
Higher mass flow rate at outlets as compare to inlet | Ahmed Saieed | FLUENT | 0 | April 3, 2016 23:08 |
trying to perform accurate mass flow rate sampling through hot-film probe | UTA_ARC | ANSYS | 0 | December 2, 2015 13:20 |
Calculating mass flow rate at multiphase flows | Kuslo187 | OpenFOAM Post-Processing | 1 | August 21, 2015 18:11 |
mass flow rate in DPM steady tracking | Roule | FLUENT | 4 | June 1, 2015 10:44 |
mass flow rate error | Masood | FLUENT | 0 | May 22, 2005 00:32 |
