October 19, 2016, 04:38 |
Wall boiling model for saturated boiling
Adil Syyed
Rep Power: 14 |
In ANSYS CFX documentation, wall boiling model is explained but only subcooled boiling is mentioned.
I want to model a double pipe counter flow heat-exchanger with hot pressurized water in the outer shell/tube and cool water in the inner tube. The cool water is supposed to start subcooled boiling in the mid section, however, at the end of the pipe, this water boils and even reaches super heated temperatures. The outer hot water shell/tube sub-cooled because of its high pressure. My question is; can i use wall boiling model? What are its limitations? And does it super heat the liquid or just assumes the vapor at saturation temperature? |
October 22, 2016, 12:34 |
#2 | |
Adil Syyed
Rep Power: 14 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 02:27 |
Setting rotating frame of referece. | RPFigueiredo | CFX | 3 | October 28, 2014 05:59 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 18:11 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
