Convergence problems with sCO2 near saturation line
Old   October 15, 2016, 18:33
Default Convergence problems with sCO2 near saturation line
Lauren Blanchette
lablan is on a distinguished road
Hello All,
I am currently trying to model a converging diverging rectangular duct with supercritical carbon dioxide as the working fluid. I am using a RGP table as the equation of state which includes metastable properties and as such instead of the saturation line included in the table, the spinodal line is included instead. With the boundary conditions specified, the flow at the throat should go into the metastable region, but not reaching the spinodal limit.
My boundary conditions are mass flow inlet and pressure outlet and I am using the total energy solver.
I am facing problems with getting the solution to converge, its stalling at around between 2e-3 and 2e-4 and has oscillating values for the pressure monitors.
I have tried a few different time scales and also messed with some of the expert parameters, but nothing as really helped in reaching convergence.
I ran a similar case in which had the saturation included and was able to reach convergence with that one, but had to use a very small time step.
I am using this case as initial conditions to the one where metastable properties are included.
I believe the instability is due to the variations in the fluid properties when nearing the spinodal limit.
Does anyone have an suggestions for me to try that might aid in the convergence?
Thanks!
Lauren
lablan is offline   Reply With Quote
Old   October 15, 2016, 20:03
There is a general FAQ on this: http://www.cfd-online.com/Wiki/Ansys...gence_criteria
But in this case, as you say the issue is almost certainly caused by your complex material condition. To make this converge you will need:
* Small time steps
* Good initial condition
* Very good mesh quality (this is critical, any improvement in mesh quality will have a major benefit)
* Double precision solver
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 05:18
8x icoFoam speed up with Cufflink CUDA solver library kmooney OpenFOAM Running, Solving & CFD 42 November 6, 2012 12:37
[Gmsh] Conversion Error nuovodna OpenFOAM Meshing & Mesh Conversion 14 October 1, 2010 12:07
Problems of Duns Codes! Martin J Main CFD Forum 8 August 15, 2003 00:19
