dynamic mesh
Old   October 8, 2016, 07:27
Default dynamic mesh
mao
mao
mao is on a distinguished road
hi,i have a question on dynamic mesh in cfx. now i can use mesh motion to surfaces, but that means i have to stop when the mesh quality below a level. now i have a idea that if i can move nodes in calculating period, which implies nodes also moving based on a given law so that mesh quality will be ensured. unfortunately, i have no idea about how to set mesh nodes moving, hopeu can give me some suggestions. thank you very much.
faithfully
xiuli
mao is offline   Reply With Quote
Old   October 9, 2016, 08:16
Mesh motion in CFX uses the motion of the boundary nodes to define a diffusion based algorithm to determine the motion of the internal nodes.
So the internal nodes already move in an attempt to improve the mesh quality.
Old   October 11, 2016, 09:27
mao
mao
good afternoon,horrocks,thanks for your kind reply.i understand what u mean,now i have a way to move nodes along blade line during the blade mesh rotating around its axis, in the other words, i have the way how to make nodes move.unfortunately, i can only find mesh motion settings to boundary rather than nodes.can u give me some suggestions?
Old   October 11, 2016, 10:12
Peter
PeMo is on a distinguished road
Beside the displacement diffusion, Glenn mentioned, you have also the possibilty to define the movement of internal nodes with a junction box routine (check the manual for further information).
But I would stay with the already implemented functionality and if you have trouble to maintain the mesh quality try to play around with the stiffness parameter of the model
PeMo is offline   Reply With Quote
Old   October 11, 2016, 18:55
For additional control on the interior nodes you can:
* Use a junction box routine as Peter mentioned
* Specify a sub domain and define the mesh motion of the nodes in the sub domain
* Adjust the displacement diffusion parameters to control how the displacement is diffused through the mesh
cfx simulations, mesh nodes moving
Dynamic Mesh on Pintle type injector. herntan FLUENT 16 September 4, 2020 09:27
pls help. mesh collapsed with dynamic mesh. wlt_1985 FLUENT 2 May 7, 2020 11:42
[ICEM] Dynamic mesh setup with ICEM David121284 ANSYS Meshing & Geometry 0 April 11, 2014 05:19
Dynamic Mesh "Shadow Wall" thezack FLUENT 0 June 4, 2013 23:09
dynamic mesh for drop interface IndrajitW FLUENT 0 March 30, 2013 09:03
