Heat transfer analysis of heat exchanger with complicated shape and irregular fins
Old   September 28, 2016, 08:28
Default Heat transfer analysis of heat exchanger with complicated shape and irregular fins
Mahesh Patil is on a distinguished road
Hi all,
I am working on a project in which I have to discuss the heat transfer characteristics of complicated heat exchanger which has varying diameter with irregular fins outside and inside. (I have three fluids and one solid heat exchanger). I tried earlier discussions and other books/documentation. But it seems very confusing.
I have couple of doubts.
1) how to calculate the Reynolds number for this case?
I know,
Velocity scale = areaAve(Velocity)@inlet
Length scale = the diameter of the cylinder or chord length
density scale = areaAve(Density)@inlet
Viscosity scale = areaAve(Viscosity)@inlet
But, how to calculate characteristic length in this case.
2) How to calculate Nusselt number, heat transfer coefficient and heat transfer rate with varying Reynolds number? (This seems complicated due to complexity of geometry)
Thanks,
Mahesh
Last edited by Mahesh Patil; September 28, 2016 at 08:30. Reason: missed one important factor
Mahesh Patil is offline   Reply With Quote
Old   September 29, 2016, 13:07
Erik
evcelica is on a distinguished road
See the FAQ for some general info on HTC and Nusselt calcs if you have not already:
http://www.cfd-online.com/Wiki/Ansys...ficient_in_CFX
You can pic any length scale you want, it is somewhat arbitrary for complex geometry. Diameter of tubes is appropriate for internal flows.
evcelica is offline   Reply With Quote
cfx, heat transfer coefficeint, heat transfer rate, nusselt number, reynolds number
