September 17, 2016, 12:36 |
using IAPWS to simulate phase change
i am trying to use IAPWS material to simulate the phase change of working fluid in micro heat pipe. but there are always errors about absolute pressure happened. does somebody have this kind of problem?
September 18, 2016, 08:42 |
Rep Power: 144 |
Make sure the simulation runs fine using a simple material model before using IAPWS. After the simple model runs successfully start with IAPWS, but use small time steps, an initial condition which is accurate (maybe the simple material model simulation), double precision. Also a very high quality mesh will help.
September 18, 2016, 22:30 |
thank u for the suggestion,ghorrocks. i have tried using simple material model, e.g. H2O and H2Ol in interphase mass transfer material, there is no problem happened. i also set time steps below 0.001s for IAPWS and used the ISOthermal model to avoid heat transfer to make sure the right using of IAPWS, but there would still be negative absolute pressure appeared in vertexes.
could u tell me whether CFX can implement the simulation include not only evaporation but also condensation in a closed system, by the way, both phases are continuous. |
use mixture model to simulate two-phase flow with phase change | dxm2008 | Fluent Multiphase | 5 | September 7, 2016 15:15 |
How to simulate the flow and heat transfer of phase change materials? | rosol | FLUENT | 9 | April 10, 2016 15:22 |
Mass Transfer without Phase Change in InterPhaseChangeFoam | Parisa_Khiabani | OpenFOAM Running, Solving & CFD | 5 | May 26, 2015 10:40 |
Flow in porous media + phase change | styleworker | FLOW-3D | 1 | June 27, 2012 15:51 |
phase change modeling | Danial Q | Main CFD Forum | 0 | April 5, 2012 02:14 |
