Step CEL expression to specify initial temperature of a geometry
Old   September 16, 2016, 03:02
Question Step CEL expression to specify initial temperature of a geometry
Nomen Ose
Peta247 is on a distinguished road
Hi guys,
I have 2 geometries attached with an interface between the bus front door and rear door. I need help in writing and applying a CEL expression which will specify the initial temperature of the outside geometry. I have the dimensions and details but i cant seem to get my expression right.
The aim is to SET the initial temperature for the Outside geometry to T=40C and T=20C for inside bus geometry.. OUTSIDE GEOMETRY DETAILS(min y = -1.219, max y =11.2255) (min x = -5.86206, max x =14.1379) (min y = 0, max y =7.60093
More picture are attached to help clarify my case. PLEASE HELP ME!!!!!!!!
Thanks in advance
Regards,
Peta247 is offline   Reply With Quote
Old   September 16, 2016, 15:31
Opaque will become famous soon enough
Are you familiar with the CEL "inside()@Locator" function ? Similar to the step function but uses mesh or physics entities, so you do not need
Let us say your mesh contains only two pieces: one for the interior, say MyInteriorMesh, and one for the exterior, say MyExteriorMesh. You can initialize the domain using the following expression
Temperature = 20 [C] * inside()@REGION:MyInteriorMesh + 40 [C] * inside()@REGION:MyExteriorMesh
Done!!
If your interior mesh is made of multiple meshes, say MyInterior1, MyInterior2, you can then write it as
Temperature = 20 [C] * (inside()@REGION:MyInterior1 + inside()@REGION:MyInterior2) + 40 [C] * inside()@REGION:MyExteriorMesh
Hope the above helps,
Opaque is offline   Reply With Quote
Old   September 17, 2016, 04:48
Smile
Nomen Ose
Thanks for your reply.
Old   September 17, 2016, 05:32
Smile
Nomen Ose
Hi Opaque thanks for your reply. Im still new at expressions in CFX. I applied the expression you recomemded i should try with the appropriate details but i receive this error anytime i apply the expression.
ERROR: Bad expression value 'Expression 1' detected in parameter 'Temperature' in object '/FLOW:Flow Analysis 1/INITIALISATION/INITIAL CONDITIONS/TEMPERATURE'.
CEL error:
Syntax error detected in the expression assigned to 'Expression 1'.
Successfully read 12 characters:
Temperature
then error detected at:
= 20 [C] * inside()@REGION:B280 + 20 [C] * inside()@REGION:B539
Details - Unexpected character.
Do you know why this is happening?
Regards,
Old   September 20, 2016, 02:58
Nomen Ose
Thanks for your help Opaque, I have figure it out
Regards,
cel expression, cfx, conditional computation, help me please, step function
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
Wrong fluctuation of pressure in transient simulation caitao OpenFOAM Running, Solving & CFD 2 March 5, 2015 22:33
Help for the small implementation in turbulence model shipman OpenFOAM Programming & Development 25 March 19, 2014 11:08
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
