""The following materials require Viscosity to be defined:Steel"" |
September 4, 2016, 04:55 |
AH
This subject has been discussed before, but still not clear for me.
Using CFX, steel dispersed solids in water. Got the error message shown above, but if it is SOLID steel what Viscosity can you enter? Thanks in advance. |
September 4, 2016, 08:26 |
Possible solution
AH
I have enetered 0.1 Pa s for dynamic viscosity which is similar to crude oil at -15C (iced) and behaves like a solid, a fair assumption for sand grain. Possible to try higher values like 1 for heavy crude at -15C. Information can be found in text books.
To do the above, select USER material. Please let me know if there is a better way. |
September 5, 2016, 04:21 |
Another attempt
AH
Through User material selection , if for example steel dispersed solids. Call the material my-metal, copy and past all the needed steel properties from the software Steel material data base. and then run. Did not get the viscosity warning message.
June 23, 2021, 11:34 |
Piet Wolff
Rep Power: 6 |
thank you, I just used that Information to get a dispersed solid working in my model!
June 25, 2021, 06:30 |
Marcin
Rep Power: 13 |
Do U try this problem to solve in Fluent ???
Quick Tips and Tricks, Tutorials FLuent/ CFX (CFD) https://howtooansys.blogspot.com/ |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 22:43 |
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 07:00 |
Adding material to CFX material library | marlon | CFX | 2 | October 16, 2016 10:33 |
error message | cuteapathy | CFX | 14 | March 20, 2012 07:45 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 09:56 |
