Transient heat flux changing in spatial coortinate |
September 2, 2016, 08:29 |
Shahid Parvez
Rep Power: 17 |
I want to apply HeatFlux [W/m^2] on a boundary between t=0s & 1s with x,y,z=0,0,0. The same heat flux is needed to apply between t=1s & 2s with x,y,z=1,0,0.
How to set STEP function for it in CEL? |
September 2, 2016, 08:46 |
Rep Power: 144 |
For your first point, try:
if(t<1[s],100[W/m^2],0[W/m^2]) As the heat flux on the boundary. I do not understand your comment about x,y,z=0,0,0 or 1,0,0. |
September 2, 2016, 14:33 |
Shahid Parvez
Rep Power: 17 |
Please read my rephrased question bellow....
I am trying to run a transient analysis for 2s. I want to apply HeatFlux [W/m^2] on a boundary between t=0s & 1s with x=0 mm. The same heat flux is needed to apply between t=1s & 2s with x=1mm. Note that x is the x-axis in cartesian coordinate system. How to set STEP function for it in CEL? The analysis is aimed to simulate moving heat source with increment of 1mm in the x-direction. |
September 3, 2016, 07:59 |
Rep Power: 144 |
The if function is easier to understand compared to step.
Try these functions: StartX = if(t<1[s],0[mm],1[mm]) EndX = if(t<1[s],1[mm],2[mm]) HeatFlux = if(x>StartX,if(x<EndX,100[W/m^2],0[W/m^2]),0[W/m^2]) And then use the HeatFlux variable as the function for the boundary heat flux. |
September 4, 2016, 14:52 |
Shahid Parvez
Rep Power: 17 |
Dear Glenn
I really appreciate your help... Can you please modify the above CEL expressions to apply HeatFlux of 100 [W/m^2] at x=0mm when time t=0s-to-1s, then at x=1mm when t=1s-to-2s, and then at x=2mm when t=2s-to-3s. I tried defining (in red colour); StartX1 = if(t<1[s],0[mm],1[mm]) StartX2 = if(t<2[s],1[mm],2[mm]) EndX1 = if(t<1[s],1[mm],2[mm]) EndX2 = if(t<2[s],2[mm],3[mm]) And then tried to add to the HeatFlux equation (given above in your reply), but failed to get the required results. |
September 4, 2016, 18:56 |
Rep Power: 144 |
You can see how these nested if statements get pretty ugly when it gets more complex.
Things you can do to simplify in include using a 1D interpolation function. Hopefully you get the idea of if statements now and I do not have to write them for you. But if it is still not working please post the statement you are using and any error message it gives. |
Inverse and Transient Heat Transfer Problem on commercial software: is it possible? | rogbrito | Main CFD Forum | 1 | February 19, 2019 02:11 |
Wall Heat Flux & Temperature | Greg Perkins | FLUENT | 10 | November 20, 2015 09:32 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
Heat Flux Wall Boundary Confusion. | Joee | FLUENT | 1 | August 21, 2010 12:20 |
udf for transient heat flux BC | isaac | FLUENT | 1 | June 3, 2004 16:29 |
